Gaz adjust front strut Spacers?
    I just put a Gaz adjustable damper in my front strut and did it up but there's definitely going to be some play in it that will allow it to rattle. After a bit of research I heard they require spacers under the insert. Could any please tell me what spacer is required and where I can get a pair? Thanks in advance.
    I recall with other short versions, folks put in washers down the tubes.
    Sujit
      That sounds a little hit and miss, I was hoping there might be something that was designed for the job. Maybe like a bump stop or polybush designed for it. Not sure how much heat from the shock friction effects what you can put in there? Maybe an ally spacer is best?
        big old penny washer been in mine since 1996. no issues yet
          I made spacers for mine on my lathe. My struts turned out to be the original type without an insert, the strut was the shock absorber......all modified when I fitted the GAZ units with which I've been very pleased..
            IIRC the gaz struts came with new locking rings. I filed the threads off the old ones so they would fit down the tubes and used them as the spacers
              Necessity is the mother…..
              2.
                I did try washers and spacers once but it wasn't very professional so i contacted Gaz to see why they wouldn't fit. They knew exactly what i wanted and sent them free of charge, as they normally come with the kit if asked for. Give Gaz a call direct there mega helpful.
                  I used a dab of silicone sealant on the bottom if mine, seems to work alright.
