Originally posted by Motorsport Micky
View Post
Anyone had this issue with CV Propshafts?
Originally posted by Motorsport Micky View PostIf you are only repairing 1 thread (what's the others like) then Helicoil it 5/16th UNF. The hole needs opening to .328 thou tapping size (the stripped hole is likely to be 5/16th which is .312 anyway) but the main problem is keeping the drill or more especially the tap to thread for the Helicoil square at 90 deg in 2 planes. Not so easy at the side of the car kneeling down. !
These studs have only about 5 thou clearance on the hub boles and if you are clumsy the stud can be put in with a lean...which then stops you sliding the hub back over the other 5 studs ! If you need to do more than 1 (surprised if you don't) then make a jig up so you can drill through and tap through square.
There are maybe a dozen threads on this in the search function...go on extend yourself, I'm not sure you admitting to being lazy cuts the mustard with continuing to receive support. !
Micky
thanks
Originally posted by Goldstar View PostCDD sell 3/8” studs Chix and can lend you a jig to fit them I believe.
https://www.classicdrivingdevelopmen...D=12&page=STAG
I used their kit to do mine a couple of years ago. It was easy-peasy with the trailing arms in situ on the car, and everything was in the kit that's needed, even down to grease & thread lock.
Micky
IMG_6749.jpegEnjoying every minute of it...
- Likes 1
Originally posted by Chix View Post
Did the whole lot! Despite some people saying it was easy/ straight forward, it wasn't... but it's done, and they're on!
Only then can the joint & loads be transmitted as intended.There are 2 secrets to staying on top :- 1. Don't give everything away.
2.
- Likes 1
Originally posted by jbuckl View Post
Nice repair of the studs… but the face is showing some corrosion…. Best to clean that up too.
Drove so beautifully up to Newbury and back, chuffed with that fix!
