Engine block questions
    I managed to source a Stag engine. The engine failed due to a bad rebuild. The heads were over skimmed and a valve impacted a piston and put a hole through it. The block appears to have been re-bored with new pistons. I have found a reputable source for a good used piston along with a good used conrod. It seems that when an engine is rebuilt the pistons and rods need to be within a certain weight of each other . I've heard 0.5 grams. is this number about right? Based on this, I'm assuming at the very least I have to disassemble the block and remove all the pistons and rods is this also correct?
    Sujit
    Yes your need to disassemble the block to weight the pistons and rods
      Sujit,
      I consider having every engine I ever rebuilt dynamically balanced at the machine shop money well spent..
      Just dug my bill out, The Stag engine was $200.
        Originally posted by trunt View Post
        Sujit,
        You can they have lots of V8s in the states, its a lot more expensive over here
          I would consider any test or treatment a good investment for our Triumph V8 engines.They are fabulous when on song, but awfully expensive when someting is amiss. If I were rebuilding one, I'd have everyting balanced if I could. Of course, you have to make sure the machine shop knows what they are doing.
          Mabel is a white 72 Mk2, TV8, ZF 4HP-22 auto.
            Ok . Thanks.
              I was quoted 400 to have it balanced and 480 to be hot cleaned
                Yes, I think that is the case, probably 70% of the work they get here are V8’s and all a lot bigger than my little TV8!
                It was also on top of the rebore, crank regrind and head job so maybe I also got a bit of a break!
                  OUCH! Maybe I have finally found something that is cheaper over here!
                  Hot cook block $40
                  Mind you he was a good old boy, retired now.. I'll have to go to somewhere slicker (and more expensive) next time.
                    Re-bore, Piston and Rods, balance , Shims and Skims, Hot cook all gobbledygook !??
                    Regards,
                    Sukhi
                      Don't forget the shot blasting, Gas nitriding, decking, and Magnaflux crack detection!!
                      canli mac izle
