Ready to fire up!!
  • trunt
    replied
    As Julian said I used a 1/4 drive socket on an extension to a drill adaptor on to the original hex drive, I did securely tape everything together to prevent anything dropping in!
    Terry
    Leave a comment:
  • singapore stag
    replied
    Originally posted by Davo1805NZ View Post
    I'm going to be at this point with mine shortly - I'd figured that I would remove power from both the fuel pump and the Lumenition box then crank the starter while observing the oil pressure gauge. Any problem doing it this way?
    As mentioned earlier , it takes time for the oil to circulate in the Stag engine, I would rather have oil circulated proper prior to start up. Don't want to take chances, I figure since its the last stage might as well be careful and do it right.
    Leave a comment:
  • jbuckl
    replied
    No problem doing that 1st, absolutely correct to disable fuel pump & ht first.
    be prepared to crank for quite some time.
    starter isn’t really up for minutes of cranking & might overheat if it takes minutes.
    Leave a comment:
  • Davo1805NZ
    replied
    Leave a comment:
  • jbuckl
    replied
    check & record rotor arm position. Remove distributor. If hex drive comes out that’s good. If not remove with a magnet.
    use a hexagon bar 5/16” instead, to engage and drive the pump anti clockwise, with a drill.
    I have used a skeleton gun hex (cut off the straight part) but some Skelton gun hex are a bit too small in their size and some are too big…. They are readily available though….
    Alternative is to use a long 1/4” square drive extension bar with an 8 mm / 5/16” socket…. Onto the original hex drive left in….But you mustn’t drop the socket into the engine when removing!
    Leave a comment:
  • singapore stag
    replied
    Originally posted by jbuckl View Post
    The jack shaft drives the distributor.
    the distributor has a hexagon shaft to also transmit drive to the oil pump.
    without that there is no chance to make any oil travel to the bearings. Per mike’s situation.
    A stag can take a long time to prime up the oil system on initial start after rebuild. (Dangerous minutes if there is ignition and fire up)
    one way to help it is to pack the oil pump with Vaseline.
    another way is to spin the hex drive with a drill (anti-clockwise) until the oil light is out or gauge pressure is seen. (A longer-reach hex is required) before allowing any fire up.
    I only fit a gauge for initial fire up to check the oil pressure…. After that it becomes a ‘worry-gauge’
    What may I ask please what precisely is the procedure for this ( red text ) I think this is the way I need to go, will give me peace of mind knowing the oil has circulated. I have fitted an oil pressure guage.
    Leave a comment:
  • jbuckl
    replied
    Originally posted by singapore stag View Post
    Sorry dont understand?? Could you elaborate please.
    Leave a comment:
  • wilf
    replied
    Mike meant that he forgot to replace the oil pump drive shaft, and was still wondering why there was no oil pressure two minutes after starting the engine!
    Mike - hope it survived?
    Leave a comment:
  • singapore stag
    replied
    Originally posted by mike@thenook View Post
    Also the drive shaft between the oil pump and the distributor - Once forgot on a newly rebuilt engine on my old Stag, never good when you have no oil pressure after 2 minutes of running!
    Leave a comment:
  • singapore stag
    replied
    Originally posted by trunt View Post
    Don't do what I did.. try to start the phone camera video without my glasses on..
    The engine started first crank but I missed it - the red squares on the screen look the same when all blurred!
    Ha ha, thats hilarious
    Leave a comment:
  • mike@thenook
    replied
    Leave a comment:
  • trunt
    replied
    Leave a comment:
  • RobinLegin
    replied
    Looks Staggering smart! Just remember to put in the oil and coolant. I once forgot on a rather sad Mini Cooper.
    Leave a comment:
  • singapore stag
    replied
    Originally posted by GrumpyOldBloke View Post
    And did it start?
    No, just doing the centre console and front and rear lights........probably after weekend ( Mon or Tues ) will make a video.
    Leave a comment:
  • GrumpyOldBloke
    replied
    And did it start?
    Leave a comment:
ankara escort
