Oil leaking from BW65 bellhousing
    Hi,
    I have gearbox oil leaking from the gap at the bottom of the BW65 bellhousing on my Stag.
    The more I drive the more oil leaks, probably a couple of teaspoons worth pools after a 10 minute drive.
    I assume I have an input shaft seal or torque converter problem and hence the gearbox will have to be reconditioned.
    As anyone experience of this and know what the likely problem is please?
    Thanks,
    Den
    Hi is it engine oil or gearbox oil(atf) thats leaking atf is normally red
      If its atf the seal on the gearbox needs changing if its engine oil the crank-seal needs replacing
        It is definitely red gearbox oil that is leaking, it is relatively new ATF, so clean and easy to spot.
        I am wondering if the torque converter is causing the problem.
        Den
          There is a seal between torque converter and the gearbox that needs changing , gearbox needs to be removed and new seal needed, the seal is easy its all the work removing the gearbox thats your problem
            Thanks Dean.
            ankara escort
