I received some good advice from a soc member recently about replacing a bonnet pull cable on my mk1 stag, but when I tried to purchase the retaining clip for the bonnet pull cable, which is fixed to the bulkhead, the classic retailers did not seem to know what I was asking for. Any help would be appreciated.
what is this clip called, does it have a part number.
Its not in the parts book.. shows the rubber grommet at the bulkhead, just as mine has..
What the heck is it for? -- why is it needed? got a photo?
The only clip I see in parts book is 611768 (also used in seat tilt cable) which I don't have either.. is that what's on the bulkhead?Last edited by trunt; 8 June 2021, 22:05.Terry Hunt, Wilmington Delaware
Here is a picture of my totally original 1978 Stag when I was stripping it for rebuild. You can see the clip above the fuel line.
IMG_0101.jpgJohn
1978 Stag Brooklands Green
Hello Roy,
Why not consider fitting a second backup release cable, as many of us have? Peace of mind about opening the bonnet means that you can then spend more time worrying about the temperature gauge
IMG_1753.HEIC
Would something like this do the job? I’m sure you can find them in a few places in the U.K. you can get double ones as well, even with different sizes on each side, I used them for my vent pipes to the boot.
[ATTACH]n820137[/ATTACH]
Can you explain the routing of the second cable, is it fitted on the other side then routed down into the engine bay for use if/when the original breaks?
As for the temperature gauge, I've got the Steve Hill kit just fitted, slowly looking at the gauge less, probably even less once I get the low coolant switch wired up
Mine is almost a reversal of the installed cable on the bonnet catch; you'll need to drill holes in the two spigots on the catch, to secure the new cable and its sleeve to make it function. I've routed mine down through an existing hole on the bulkhead, and made a bracket which bolts under the back of the driver's foot rest, then attached a large ring to the inner cable to pull. I probably use it more than the original, as my car is parked in the garage up against the passenger side, and it's easier to access through the driver's door for opening the bonnet.
Others on here may have different designs or routing.
- Likes 1
Thanks all, for clarity - here is a pic of the clip I am referring to
My Stag is a MK1 and Tony appears to have hit the nail on the head
