The passenger door on my Stag is off centre, any advice on adjusting the gaps?
Door alignment
Originally posted by PaulShaw View PostCan I ease the door card off at that end to get to the bolts without taking the whole card off?
is it just clipped in?Last edited by trunt; 19 February 2021, 16:30.Terry Hunt, Wilmington Delaware
Worth getting a copy of the ROM (repair operations manual) if you haven’t got one, which is where my picture came from. While you’re waiting for it to arrive you can print the pages you need from the Hrampian Stags website. Makes a lot of Jon’s a lot easier.Paul - 3 projects, 1 breaker - garage built and housing 2 white Stags. One runs, one doesn't
Be careful to keep the window frame where it should be so the seals touch. It does not have much adjustment.
this means that the door gaps need to be thought about in conjunction with the frame position, usually at the body restoration stage.
metalwork adjustments ie removing or adding steel have to be done at both ends of a door ideally, not just at one end.There are 2 secrets to staying on top :- 1. Don't give everything away.
2.
