Differential Rebuild Recommendations please
    This year I'm planning to get my differential overhauled and wondered if there are any specialists in the South of England please. I'd also be interested in hearing peoples opinions and advice on changing to the 3:45 ratio. The car at this time is fitted with the BW35 auto box. Thanks.
    I love deadlines - I like the whooshing sound they make as they pass by!
    Hardy engineering there in Leatherhead
      Rob.
      I think you will find the 3.45 ratio is a great improvement with that auto box. I did. Goodness knows why Triumph didn't fit it in the first place.
        +1 for the 3.45
        Cheers Ian A
          Although not in the South, I (like many others here) got mine from TD Fitchett. They send it UPS next day and it only cost me 11 via parcel2go to send my knackered exchange one back to them from Ashtead, which is right beside Leatherhead.
          Jeff
            I know richardthestag also had a recon diff from Fitchett that he was very happy with. About 500 from memory
              Yes, same price now. Excellent unit.
                Thanks for all your recommendations, I'll give T D Fitchett a call.
                  An update after my call. They have the 3:45 rebuilt unit in stock at a cost of 550 +vat with a 300 surcharge against me returning my old unit, very reasonable all things considered.
                    You won't be disappointed!
                      + 1 Excellent product and good service
                      1976 MK2 TV8 ZF-4 HP-22 Auto, Inca Yellow, Minilite Replicas, Stagdad Pump
                        Another +1 for diffs & racks from fitchetts.
                        2.
                          In preparing to do this job I've read the ROM and it seems to be a straightforward job of removing the Hypoid, am I right to assume the propshaft and nose extension piece stay in situ and the Hypoid pulls off the splined shaft?
                          I'm also planning to fit the 3:45 ratio unit as many people have recommended but in doing this is there anything extra I need to consider before doing the job and are there any 'gotchas' anyone can advise upon?
                            Yes, did it a few weeks ago, worst part is removing the exhaust pipe that runs underneath!
                            If you wanted to, the extension bearing can be replaced with it still in-situ but keep in mind that the advise is to use a good quality bearing for that..
                            Terry
                              Put mine back in yesterday. Definitely helps to have another pair of hands to keep it steady as it is jacked up although with gravity helping it should be ok on the way down solo.
                              ankara escort
