No. They are firmly fixed to the inlet manifold. Any movement might mean that the centre fixing is loose, which might mean that the 'O' ring is perished.
Alan.
Or that the thread holding the pedestal fixing stud into the manifold has stripped so it can't be tightened. It isn't a major problem if it has.
That's interesting - I can feel a slight sponginess on my carbs too. Everything is tightened down, no stripped threads etc. I was under the impression that it should be that way so that the carbs were isolated from engine vibration or temperature? Other carbs I know have a plastic "insulator" for that purpose.
My inlet manifold has a small down type pin on the outer edge of the circle which lines up with a hole in the base of the carburettor manifold, however there is still a very small amount of movement. I will try and load a photo if I can.
Exactly! This is why I was led to the belief that the carb sits on the squashed O ring and can move slightly but the pin stops it all from turning.
+2, very slight movement, as said it sits on a O ring, if it doesn't move maybe the O ring is flat and not sealing 100%, not all O rings are the same!. best to take it off and fit a new seal/O ring.
Carb pedestal has to be in contact with manifold.
Oring is only for sealing. Roll pin is a locator.
any other arrangement will allow the nut to come loose& or an air leak.
2.
I'm at the stage of re-fitting the carbs on to my rebuilt engine and find that the pedestal O ring seems to be too small - it won't sit in the groove while I drop the carbs on to the stud. I did some searching on the Forum and read in another thread a suggestion for how to fix an O ring which had become too big - does anybody have a fix for one which is too small? Thanks in advance for any advice.
Dave.
If it is much too small, I would buy a correct size one from a supplier who takes the trouble to stock them! Otherwise a bit of gasket sealer might hold it in place while you replace the pedestal.
