Automatic gate illumination
    Hi all , the small gearshift arrow shape which shows what gear you are in , my arrow shows the bright white light of the bulb below it , I suspect this should be green , what is missing on my unit (on the sliding metal piece) can’t see anything from the suppliers ? Regards Graham
    I believe a foil was listed for this.
    however I have never seen one on a car....once saw one nos on eBay.
    I have remade the green tinted legend for 3 & 4 speed autos. These are available to make (files) or I can post if you have a new blank surround.
    I have fitted a green led instead of the white festoon bulb.
    2.
      the selector transfer/perspex has a green paint like coating on the reverse side, the lever has a slide so you should not see any white light, but saying that I have a zf22 4 speed and my lever surround is currently loose so I see the light!
        Only originals had the green legend. New surrounds are left blank...hence the need for the glue in legend (green backed) I made available. Files are in technical section & on Facebook. Or I can post 3 or 4 speed legends, ready made, no cost, for glueing into the new blank surrounds.
        2.
          Thx for replies , I mean the arrow indicator that moves with the t handle as in my photo , I would think that should have a green lense or something
            Buy a green LED bulb
            "The UK,s Most Easterly Stag" Quad Exhaust- ZF 4 Speed BOX
              The arrow-shaped cutout should have a piece of green translucent tape under it. The glue has probably dried out and it has fallen off.
                Thx guys ! I think the green led bulb will do the job , regards Graham
                  Here you go
                  If its too bright for you, turn the bulb so faces inwards or run a black marker pen up the glass to dull it down a bit
                    Thx for that MandM ,shall contact them tomorrow
                    antalya escort
                    canli mac izle
