Hi All,
I've had a problem with my wipers where they only worked on slow speed, would just stop if went to fast and would not park. I've been through the forum and all the good advice pointed me in the direction of checking voltages.
I had recently bought a new wiper switch from the brothers as my old one had snapped, it turned out two of the pins in the connector were in the wrong place. At first I though it could have been my wiring but it matched the wiring diagram and it was definitely the switch that had two pins were incorrect. I swapped them round in the connector and now the wipers work perfectly !
Not sure if anybody else has had this problem but if you do by a new wiper switch might be worth checking that it is wired correctly. when selecting the off, slow, fast etc the following pins should be shorted out, you can check with a multimeter.
Off - pins 4 and 5 should be connected
Slow - pins 1 and 5 should be connected
Fast - pins 1 and 3should be connected
Int - pins 5 and 6 should be connected and 7 and 9 should be connected
washer - pins 1 and 2 should be connected.
i.e. select position 1 for slow wipers and place the multimeter leads on pins 1 and 5 and the meter should show short circuit.
Hope this is of help somebody.
