I've had problem with my ignition light staying on and not activating the alternator. After accessing the dash and rear or cluster, I found issue with a loose wire connection seated into the socket that then accepts the pins from the cluster gauge.
Is there a way to push the wire connections out of the socket so I can resecure? I have tried a removal tool that has several different pins and have not been successful in finding one that works. I recently removed the dash and harnesses to re-veneer dash and hope not to have to do so again for one wire connection.
should I just insert some wire from the rear to take up tte movement and leave it at that?
Thanks, Matt
Thanks, Matt
