While I am progressing with fitting an A/C system I needed to sort out a better power distribution supply for the electric fan, AC clutch and future headlight relays. I also needed to free up space to fit a new radiator overflow bottle and the windscreen washer bottle as well as give more space for the new AC compressor ............so I decided to relocate the battery to the boot.
I had done a similar job on my Alfa so I knew what was involved and what parts I needed.
First task was to construct a tray to hold the battery on the left side of the boot. With some mild steel sheet and some brackets from the hardware store I made a battery holder, bit over engineered but I tend to think a bit more is a bit better than just enough. Its not pretty but solid and managed to use the two existing threaded screw fittings in the left boot area to secure the rear of the holder and welded a bolt to help secure the part of front of the battery holder.
I also used the left rear bumper bolt as a securing point to hold one of the battery hold down rods and drilled a hole on the other side of the holder for the other hold down rods. Need to tidy it up and make the hold down bar then on to creating a suitable path through the inside of the car to run the large #2 size power cable up to a new power distribution point in the right hand side of the engine bay. DSC00379 (1024x768).jpg
