Now that I have sorted the engine mounts in my Rover 3.9EFI stag it is time to fit an after market AC system.
I decided to go aftermarket as I had already done a similar fit to my Alfa 105GTV so I knew what I was getting myself in for.
Like the Alfa I decided to put the evaporator in the space where the glovebox normally sits, loosing the glovebox is a small price to pay to having AC in warm climates like Australia.
I needed to move the fuse relay panel to make space but luckly there was still enough room to leave the fuse box in its original position.
The evaporator came with a mounting bracket which I attached to the dashboard support bracket by making a couple of L shaped brackets and then bolting it all together.
I had to make sure there was enough room for the air ducting tubes to be fitted to the front outlets which will feed the vents at the end of the dash and the centre air vent.
Started to make a trunking to join up with the centre air vents from some leftover thin gal sheeting.
