Good Morning All,
over the last few days i have been trying to help a mate with his stag has he's had a few issues with it, here goes:
over the last 4 years he has had a temperamental problem where ocassionally he would turn the key and it would click and not start, however after a couple of times it would start and drive for miles, he took it out the other day and left the stag parked while he went shopping and when he came back it wouldnt start and there was a clicking sound, anyway after a few attempts she kicked into life and got him home where it hasnt started since, he bought an exchange starter motor and solenoid from robsport however after he fitted it correctly, she still wouldnt start and there was a faint click still present when he turned the key but after a few attempt she started however only for about a second and thats it, i have been trying to help him with it as i know a bit about mechanics etc, the first thing i checked was the battery which only had 11 volts in it however i have replaced that for him to a newer battery with 12.8 volts which is good, however still no joy,the next thing i checked was the fuel pump which is only a few months old and working fine, it has a lumenition ignition which was fitted around 10 years ago and seems to work fine, i noticed smoke coming from the coil which isnt good so i have replaced that, also the distributor cap and rotor arm were in bad condition so i have replaced them, it has reconditioned carbs on it fr om rimmers which were absolutely disgusting considering they are only 18 months old, i noticed petrol leaking out of them and all the carb bolts and screws were loose, however i took them off and gave them a good seeing to, so they are now sorted. my mate reckons he took it down to faversham classics about 18 months ago to have some work done including a tune up and new plugs etc. however i took out one ofthe plugs to check it and they appear to be very old bosch plug which havent been changed in years, which were all gunked up with carbon and corrosion, i have told him to get a new set of ngk bp5e s today which i will fit this evening, however im convinced she still wont fire up, i have tried easy start etc direct in the carbs, howver after ive done the plugs theres not alot else i can try, also to note that after 2 attempts of starting where it sounds like it it wants to go there is a wirring motor noise coming from the starter solenoid when i turn the key and nothing happens, i have to leave it for 5 mins and then it will let me attempt to start it and this is what keeps happening,
any advice would be appreciated as to what could be wrong.
TIA
jamie
TIA
jamie
