Misfire and lack of power when hot
    Hi, I hope someone can help me diagnose a misfire on my 72 stag when the engine is hot and under load. The cad has not been run for a while until last week and it started fine and ran ok for a few miles. However it then started to misfire and lose considerable power. Suspecting the coil, I fitted a new Lucas DLB102 but again the same issue occured when the engine gets hot. I have checked wiring to the coil and ballast resistor, all of which is ok, regapped the plugs, checked the HT side and I am getting sparks. The car has a lumenition ignition system on it.
    Fuel is getting through ok looking at the fuel filter and Icant see any other obvious issues.
    If anyone has any other ideas where to look next, I would be grateful.
    Thanks and regards
    Dave Harris
    Hi Dave
    just something simple to check, is there enough oil in the carb dashpots....
    Neal
    1972 White Manual and loving it
      Hi Neal, just checked at they both have enough oil in.
        Dave.
        Another suggestion. Over the years I have had similar symptoms in hot weather, and on both occasions it was the Lumenition system starting to break down. They seem to become heat sensitive with age.
        If you don't find anything else wrong, it might be worth getting it tested, but that might not be easy at this time!
          I always suspect the coil have you got another? Not unknown for a new one to be duff and Lucas branded stuff is not always genuine. Otherwise have you got another set of HT leads - one or more might be breaking down and giving a high resistance exacerbated by heat. Hate these kind of faults. Good luck
            Had a similar issue recently, would run fine from cold for approx 15 mins then start to misfire as if running only on 6 cylinders, turned out to be the red pick up module on the Stag Webber electronic dizzy, wasn't a perfect fit and too close to the pickup rotation, when everything warmed up and expanded they both touched causing the miss firing issue. I too tried all the usual suspects, had me going for a few days.
            Roger S
              Thanks for the advice. Plenty to check out, hopefully I will find the issue.
                Just had to fit another powerspark. The pickup could not be adjusted for clearance without filing out the mounting plate. However the car wasn’t missing or misfiring, there was no spark at all.
                +1 for Paul’s comment about Lucas dlb could be the issue.
                fitted a Bosch after the Lucas caused missing when hot.
                2.
                  +1
                  I had leads go and a coil go. New Bosch red coil and Magnecor leads it solved it.
                  Jeff
                    Change the rotor arm.
                      I had similar hot misfiring and replaced the opto sensor on the Luminition and it was fine afterwards. I have heard this is a relatively common problem
                        remember that 90% of ignition faults are fuel related and vice versa
                        On the ignition side and assuming that luminition is in good order.
                        When it starts to misfire, run a wire from battery +ive to the feed side of the ballast resistor, does misfire go away? = break in white feed for Ballast resistor
                        Replace the wire that sits between ballast resistor and coil +ive, just bridge it, no misfire = break in wire that sits between BR and Coil
                        Is the trigger wire for the luminition to -ive sound. I have had terminals that look fabulous but are only one strand away from breaking
                        What rotor are you using in side the distributor? does it have a rivet holding the metal blade to the body? = cheap crap
                        I have more failures from cheapo rotors than anything else, got a box full of the damned things that work fine on the bench test but fail in operation. some even wobble the distributor cap when the engine is running!!! wrong size rotor chaps.
                        likewise for the cap - the market is flooded out with cheap nasty crap
                        Said it before and i'll say it again distributor doctor is the only place I buy ignition components from now. Too many failures, to many fakes, even green boxed lucas is not that great and has let me down
                        All that said, have you lobbed fresh fuel in? a tank full of unleaded that in a car that has not been used for months is pretty dreadful, goes off really quick. Super unleaded lasts a little longer. fresh fuel make make the world of difference
                          A lot of good advice ^^^^^
                          I would be looking at the rotor arm and the coil. I had a misfire a while back. Bought a new Lucas coil from a respective supplier and it too failed when hot. Bought a Bosch Red coil and no problem since.
                          Another thing to check is the plugs and leads. Both can fail when hot.
                            Yes I think its a Power spark kit that Stag Weber use. That was the issue with mine, I had to file out the plate fixing holes to get the correct adjustment. This is how I found it, the gap is supposed to be constant at approx 1 mm, I had no further adjustment until i elongated the fixing plate holes.
                            Roger S
                              Interesting thread and exactly this happened yesterday when my wife tried driving the Stag for the first time.
                              I had no power at all, could barely get going and not at all on a mild incline. Being automatic, couldn't rev up and slip the clutch.
                              I drove it for a short drive today and it was fine so I'll go through this thread and get some spares to try.
