Hi All
I'm replacing an outer sill, outer inner wheel arch and a 3/4 rear wing, I’ve jacked up the one side just to make it easier but wondered if this is twisting the body slightly as I don’t want to weld a twist into the car should I do the sill on 4 wheels then remove the wheel to do the rest? I’m bracing the door gap. Look forward to any advice
thanks Alan
thanks Alan
