OK, got my sender from Rimmer. It has a black insulator if that means anything. At 68 F, it reads 920 Ohms. @ 185, it reads 65 Ohms.
Now, my gauge had an add-on resister on the back. Clearly OEM, not a hack. Gauge reads 61 Ohms @ 68F. Resister is 14 Ohms.
With the resister, boiling, I read just past the center mark. Without it, gauge reads right on the third tick mark. Without, 185 was pretty close to centered. So, with THIS sender, I want no resister. Bench test, regulated 10V supply and I will be using a solid state stabilizer.
Clock fixed, temp gauge fixed. Voltmeter good. Speedo cable on order. Tach good. Now to test/calibrate the new tank sender.
