For anyone thinking of changing wheels or tyres to a different size
    This is the most comprehensive website which shows you exactly what changing your wheel type/size and the tyres to fit will do to your car and what pressures to use too.
    There are others but not as good as this.
    https://tiresize.com/calculator/
    https://tiresize.com/comparison/
    https://tiresize.com/pressure-calculator/
    Thats a good site, i changed from 13 to 14 on the dolomite fitted stag wheels
      Mike do you know what the correct offset is?
      I know you have had a range of wheel and tyre combinations.
      Phil
        Hi Phil,
        I’ve an absolute library on the subject now!
        A normal Stag alloy has an offset of 28 and I’d normally use 195/70 as a tyre profile to give a template for others.
        Quite interestingly the guys at JBW wheels suggest an offset of +8 with 15x6 wheels which if fitted with 205/60 x15 tyres come incredibly close to the overall set up I have with 205/55 on my 16” wheels with a +6 offset.
        Its good to play around to see what works best within the confines of an unaltered arch.
