Testing Stag ignition, standard original electronic ignition - no spark at plugs
    All worked fine before I took gearbox out, now no spark - there is power and a spark at the coil,and i've checked all connections etc. HT leads are almost new.
    How do I test/check the electronic ignition - any idea why it might fail when not used - been fine for layups before. Does this have any effect on, or connections to the fuel pump cut out swicth by the fusebox?
    1973 Stag 1982 Acclaim HL 1985 SD1 Vitesse 2006 BMW R1200GS
    2008 Skoda Octavia VRS
    There was no standard electronic ignition (only aftermarket fitments)
    If you've got spark at the coil then the electronic ignition is probably OK
    Do you have spark at any of the spark plugs or none?
    Check
    King lead
    Distributor cap (is is fitted correctly and is the carbon brush inside broken?)
    Rotor arm (did you forget to refit it?)
    Plug leads (if you have no spark at any cylinder)
    Spark plugs (is the one you checked the only one not working?)
    Simon
      Sorted, one wire on wrong way on coil, the other redundant from loom for original points ignition.
