Steering rack fittings
    Ok, what I have is not correct as some PO buggered it.
    Anyway, for the cross over pipes, into the valve body is a 7/16 x 20 fitting that I think is sealed with a copper washer. ( one side had one. )
    It receives a 1/8 inch pipe fitting. PIPE?
    I had a 7/16 inverted flair to 1/8 pipe adapter
    The pipe is 1/4 inch with standard 7/16 inverted flair nut.
    Of course, they routed the pipe behind the cross-member so yo can't slide the rack out easily.
    Somehow I suspect this is quite wrong.
    What should I have? Is there a supplier of these pipes made up?
    Found James Paddock had the lines. On order. Still strange fittings, but at least I'll start with the correct lines!
      Don't knock your PO too much, he kept it going so you could get it.
      John.
