Breakthrough on stripping undercoat
    OK, best rough method is heat gun and scraper, but getting the residue off was being a problem. Paint thinner, lacquer thinner sort of work, but highly volatile. Don't care for using gas as a solvent.
    PB Blaster! Works like a charm. Does not evaporate too fast so it can break it done. Wipes off. Then you have to just wipe it down with thinner before painting. HUGE advance. Great now I am down to just one inner fender!
    Not the nices of jobs to do,but i use a wire brush on a angle grinder,go over it once to get the worst of,then change the wheel go over it again with new wire brush,but wear gloves your need them
      For me the wire brush was impossible, it throws it everywhere and makes a hell of a mess. Eventually I used one of those oscillating tools with a little heat from a heat gun, peels off a treat.
      Terry
        Terry
        Yes i know it makes a mess,like i said not the best job to do,but its quicker,the trouble i found with heat gun ,it melts bits that land on your hand it takes you a miniute to relize your being burnt and then you cant get out from under the car quick enough oh the joys of a Stag
          I guess a wire brush works on some of the older tar, but not on softer rubberized undercoat. Anyway, my post is for getting the residue off. Heavy stuff I use a heat gun and putty knife. The only method that worked for me. Don't have to heat enough to melt. Just soften a bit. Heat about a square foot and let it soak in so the metal is warm. Thin gloves help. I tried a scaler, power chisel, and an oscillator. None were any help. Taller jack stands were a big help ( 6 ton type)
            Have the prices come down on the lasers yet
