haedlamp bowl split pins
    can anyone help? i have read a few of the threads on the subject of split pins/bolts and why split pins from new?
    cant see anyone in these threads that has changed to a nut and bolt?
    i can only seem to source the full headlamp adjuster kits at about £8.50+ each light which then come with a new pin and rubber...……...….. as I need 4 it seems a lot really just for 4 pins
    does anyone know where I can source the pins alone or has ideas on what to replace them with?
    thanks
    si
    Woolies trimmers sell,Bifurcated rivets but not sure if there be big enough for the head lamp bowl,the cheapest way is a bolt with a locknut,i had the adjuster go on mine it was going to cost me £80 for two cars,in the end i bought stainless steel bolt drilled them put a split pin in,a nice easy modification
      rimmers have adjuster kits at 4.14 per lamp
        Rimmers head light adjuster kits are £10.20 per headlight
          I found the same for part number 520403a. Do you have a link Phil?
            kit bmh 7058
              kit bmh 7058
              Phil
              how did you find them,there better than the originals
                google
                  Sadly I don’t need the adjustments and there does not appear to be a pin in this kit just a spring?
                  Thanks for looking
                  Si
