Strut brace
    Strut brace
    Hello,
    Im thinking of fitting a strut brace and don't have the facilities to make one
    .I know that there is supposed to be an improvement in stability handling etc
    After a brief look on line cant see where to buy one,was wondering,
    A : where people bought theirs from?
    B: What if any noticeable improvements where noted,
    Thank you in advance
    Mark
    Hi Mark,
    I don't know about buying a front strut brace for the Stag, but have a look at post #105 for how our fellow member bullstarz did his. I assume it is one he built himself.
    https://www.socforum.com/forum/forum...vti-stag/page3
    As for noticeable improvements on a standard Stag I have no idea, it probably won't hurt but if the body is otherwise solid I assume it's not going to make a significant difference to the handling.
    Joakim
    1975 Triumph Stag - TV8 & MOD. Still in sickbay...
      Originally posted by jagorstag View Post
      Hi Mark,
      Joakim
      Hi,
      Joakim,
      yes read that thread,Bullstarz made his as said ive not got the facilities, but thank you
      cheers Mark
        Hi Mark, I know, but maybe there is a local metal workshop you could ask to make one for you? It probably wouldn't cost a whole lot, just a thought.
        Joakim
          I have been thinking of doing one for a while, I made one years ago for a mk2 lotus cortina and the difference was noticeable.
          I now have my lathe and mill home and working, so will post pictures if I go ahead
            Hi Maverick, I don't have one, so can't comment on their effectiveness, but Demon Tweeks sell them.
              Monarch used to sell them, but no longer...
                Thanks Phil would like to see pics
                  Hi
                  I guess that's not Stag specific,
                  Interestingly some where made by Canley classics copied from for the Triumph P.I rally car in 70s,i don't know if they would fit
                    With the ZS carbs, a standard strut brace would be difficult, but the "Monte'Carlo" bar would seem to fit just fine. The difference between the two diagonals, Ford's innovation was to make it one piece to make it a "frame" rather than two "truss" positions. ( in statics speak)
                      Just seen this thread. Yes i did make my own and was one of the simplest and straight forward things Ive done to the Stag. It made a difference.
                      "Many vehicles, including the Stag, use a MacPherson strut system in their front-end suspension. This means that the strut is a part of the steering geometry of a car, and the simple MacPherson design is inexpensive while still offering a relatively comfortable riding experience. One of the disadvantages is that they transmit their load up through a strut tower, which can cause chassis-flex. Strut bars try to eliminate this problem by increasing the rigidity of your car's chassis to keep it from flexing when you're cornering.
                      Joining your shock towers together gives your vehicle improved handling and greater rigidity, two important upsides. This is more important for people who have upgraded their factory suspension to one with stiffer/harder springs than the original. Some performance-oriented packages include a strut tower brace with their springs because of the difference that it can make to a driver’s long term enjoyment of any suspension modification.
                      Better cornering and less body flex are two additional benefits that have a positive effect on driver experience and will help you really enjoy your Stag. Even better, because strut bars are so easy to install, they’re equally easy to uninstall. If you dislike the feel of the ride, it’s easy to remove your strut brace. It’s a pretty low commitment modification.
                      The cons are that a strut bar adds a small amount of weight (really negligible), and they give the car a slightly stiffer feel that casual drivers don’t always find as appealing as enthusiasts."
                        Thank you Bullstarz,
                        ,the article is very interesting and relevant to me,
                        I know you made yours but unfortunately I don't have the eng facitities.
                        Heres a pic of the triumph 2.5 pi mexico rally car version,sorry cant post it
                          Mine was made using two hole saws, a drill, a mig welder ,some steel plates and a 15 or 20mm bar. All quite easy to make.
                            heres the picture of Triumph 2.5 P.I mexico rally car strut brace,does anyone know if the distance between the struts is the same as the Stag in other words would it fit?
                              The Stag strut tops are nominally the same as the big saloons but the carburettors would get in the way of the PI brace illustrated. A similar brace for the Stag would have to be further backward where there is a small amount of clear space.
                              Mabel is a white 1972 Mk1, TV8, ZF 4HP-22 auto,
                              2016 RBRR finisher. 400 mile C2C 21/22 April 2018!
