Hi all,
just thought it has been about 5 weeks since I exercised the Stag. So I took it for a quick outing in this sunny weather. The engine was lumpy and mis firing. I put that down to crud in the carbs. Will check that out over the weekend.
BUT as I drove across the ranges near the tank museum, I noticed the red ignition light was on. I checked under the bonnet and found the alternator belt has failed. It is a new alternator. I would appreciate advice on the following please:
1. What size is the belt and does it come fit for modern cars so can be purchased off the shelf?
2. How do I go about replacing it without dismantling the radiator and other bits on the front end? Is there a mechanics favourite shortcut?
thanks
thanks
