kenlowe thermostat seal ring
    Hi, does anybody know if its possible to get the rubber sealing ring that allows the capillary tube to be fed out of the top hose connection ? thanks in advance for any info, Derek
    Derek,
    Yes, I think they do a silicon liner that allows the sensor to be inserted and then the liner/sensor are covered by the top hose.
    However, being a cheapskate, I fitted a new top hose and cut and trimmed part of the old one to taper a small section and cut a groove on the outside to allow the sensor to pass over the tapered section/in the groove, and then be trapped by the top hose, a little bit of sealer when fitting, and it worked fine.
    Ian F
      Hi Derek,
      if you telephone or email Kenlowe they will send you a couple for £5.60 - I just did this last month.
      It’s part number KLM2213
        Kenlowe Seal as supplied with Fan Control Kit. Allows you to fit the sensor of your fan controller into your radiator and make a water-tight seal.
        Holden also do them but Mike's pri e is better.
          Thanks very much to mike and brian, I will phone them tomorrow, Derek
