Inlet Manifold leaking, damaged insert, may help someone
    My Inlet manifold and water pump have been leaking slightly for a couple of years, so thought it was time to tackle them, when I took the manifold off one of the Wurth thread inserts was broken, this insert was fitted to a thread that was heavily damaged by a previous owner, and had a 3/8 bolt in an oval hole. The insert fitted by the machine shop when I did the heads, must have not been fully supported all the way up the thread as it parted.
    so I removed the other half of the insert, and set about thinking of a solution. Time inserts do a Big insert but the kits are very expensive, so I made an insert from a m12 stainless bolt, tapped out with a 5/16 UNC thread. But was nervous about drilling the head out to M12, so had a look about and found an old head stud and drilled that out with a 5/16 UNC thread, the outside diameter now being 1mm smaller in dia. than the m12 bolt.
    So with drill in hand I drilled the hole out to 9.3mm and tapped to 7/16 UNC to take the insert,
    P1080714.JPG I then turned the length down to suit the hole
    P1080721.JPGP1080726.JPG and thread Locked it in.
    Hope this may help someone out of a hole , pardon the pun.
    Just got to do my water pump and get the manifold to seal now!
    "The UK,s Most Easterly Stag" Quad Exhaust- ZF 4 Speed BOX
    Good skills! Necessity is the mother of invention as they say!
    Sometimes you just need the 2 wheels!
      Very good. Please post to Technical Section.
      Cheers Ian A
        Excellent job
        1973 GT6 Mk3 Pimento Red
        1974 Stag MOD,3.45 diff,French Blue, Fiat seats, Belt EWP, H/Tank
          I managed to find a picture of the original Hole before the first insert fitted by the machine shop, and the broken bolts by the other ports, right mess
            Thought I would add some more photo's of my water pump as well that may help someone
              More
              Add the oil thrower to the shaft then the bearing and cir clip, then fit the bearing and shaft assembly to the cage before fitting the seal (not as first picture) on the shaft and make sure it's fully home/fitted in the cage. don't ask me how I know. add water thrower and new ceramic water seal, machined impeller and torque up.
                I have made some blind inserts, if someone had drilled into a waterway while I still had access to a lathe.
                  Hi, concerning the repairing of the water pump, I can see that you got a now repair kit. I ordered one kit too, but the oil thrower (part no. 147266) seems not to be available.
                  May I ask you where did you get the new one and where can be the part be purchased ?
                  Thanks in advance for any hint.
                    Here. LDparts usually carry them but are out
                    http://ldparts.co.uk/shop/shop.php?c...6d19a2f65c5d31
                      Do they have the oil thrower too ?
                      The link refers to the water thrower (Part no. 148462) which is available at James Paddock.
                      I need t part no. 147266) see pic enclosed
                        Try Robsport or Tony Hart as they rebuild water pumps
                          Excellent skills Martin, I bit of thought and a super solution.
                          1976 MK2 TV8 ZF-4 HP-22 Auto, Inca Yellow, Minilite Replicas, Stagdad Pump
                            Thanks, I did think that as well , I did make somemore before I left work use all my old studs up, some blind some striaght though, may help somone out in the future
                              Managed to make a similar insert to repair an iron thread in the exhaust manifold.... also from an m12 bolt. screwed & Brazed into the manifold.
                              previously someone had drilled it through for a nut & bolt and the lug had split.... had to weld the split first.
                              Nowadays I would fusion gas weld the lug & re tap it.
                              2.
                              antalya escort
                              canli mac izle
