Hi all...again. For the last 3 yrs I have had trouble free motoring, but know it would seem my chickens are coming home to roost. Its one problem after another. This time its is leaking float chambers. First time carbs off, tighten all screws. Worked fine for a day. Next carbs off again, this time take float chamber apart and adjust float levels which were quite a way out. Worked for a couple of days and have to say cured the hot start problems that I have been having, but started leaking again. Carbs off again, this time I fit new float chamber gaskets. Started leaking 30 seconds after I started up. Any suggestions? Whats the opinion of now using gasket sealer. Any particular gasket sealer? I bought dirko sealer from paddocks a while back. Can this be used? Sealer on both surfaces with gasket in between. Any help would be really appreciated. Sick of taking carbs off!
Mark
Mark
