Nearly Drew. Mine was in metalwork. Was a CAD designer in a previous life - pre retirement.
Hardtop Hoist
Originally posted by Paul Goldsmith View PostThanks for sharing - You look like you've found the ideal balancing point - what's the distance between the bars and the position of the lifting eye please ?
I've taken some more photos. The lift point to door is 3 inches in my set-up. Hope photos help.
I used 2 roof bars, so that when the hardtop is raised up against the garage roof it does not move (tip), but there is no pressure on the hardtop roof. The PO had put some dents in the hardtop roof - I have to get fixed.
Lift plate.jpg Hook to rear rail=4.5 inch.jpg Rear to front rail= 14.5 inch.jpg Door open to rear rail= 7.5 inch.jpg
Jim.1976 MK2 Signal Red TV8 MOD
Awesome !! Thanks for all those pics Jim, much appreciated (Julian too).
Those Halfords roof bars even look v similar to my Paddy Hopkirks, which I was chuffed to pick up from FreeCycle.
This evening I unboxed my electric hoist and tried it out for the first time since buying in a Maplin sale several years ago - I can't wait to get the bolts, eye and metal strip next week - a bit sad I know
Originally posted by Billy Gough View PostHi Jim in process of copying you. does roof rack need certain type of connectors to avoid damaging shiny rail trim please?
thank you Bill 09656 recently re-joined
I used a Halfords roof rack but as long as it has rubber or plastic protection where it clamps on the gutter rails you shouldn't damage anything.
Good luck
2 x reasonably strong people - 50 - 55kg IIRC. Some folk remove the sprung plunger at the rear as it's easy to damage the hood cover and doesn't seem to make ant difference to its security. Mine hasn't been back on since I transferred it onto a stand ~6 years agoWhite 1976 build ("Mk2") only a few mods
- Likes 2
Originally posted by KES View PostJim
What is the sizing of the flat bar joining the two roof bars? Looks like it might be 4mm or 5mm thick by 75 or 100 mm wide. And what steel, assume mild steel but it looks bright ... ?
Thanks
Keith
Sorry for the late reply, only just seen your post. The bar is Galvanised steel. It's 5mm thick and 57mm wide. I think I got it from a local agricultural suppliers.
Jim1976 MK2 Signal Red TV8 MOD
- Likes 1
