Pretty much since I got my Stag (LD250) the clutch has been a switch (it's either all the way in or all the way out...there's no smooth biting point). An oil leak from the cam covers had been filling the bell housing and the gearbox leaks oil from everywhere. So I've finally bitten the bullet and got round to fixing it. The gearbox came out today and I think the biggest problem has been caused by rust on the splines between the friction plate and the input shaft. As often seems to be the case with old cars, evidence of previous bodged jobs has come to light...like one of the locating dowels from the flywheel is missing and the anti rattle pin and spring is missing from the gear lever (these will be rectified). I also noticed odd marks on the propshaft. Now that the shaft is off I can see that it has been caused by the fuel pipe not being secured properly and touching the propshaft! I dread to think what would have happened if it had worn through.
New bits have been ordered from Paddocks and I think I'll overhaul the gearbox while it's out as there was some metal filings on the magnetic drain plug.
Chris
Chris
