tailpipe
    tailpipe
    Anyone know the difference between the big and small tailpipes,and yes i know ones big and ones small
    i mead does anyone know the measurement inch or mm.you see i want to buy one, and need to make sure i get correct one Cheers
    Cant help with sizes,but the small bore is the original size and would be my preference..
    Sam
      i know the large bore is 3 inch dia,just had one made
      dave
        Hi Greystag,
        If you are looking to just replace the tail pipe section with a large bore from one of the main suppliers, the diameter is two and a half inches at the outlet under the bumper. There is no difference in pipe size as these directly replaced my small bore tail pipes. If your doing it to get a better sound, don't bother, my small bore tail pipes made a better sound than the large bore does. If you do go ahead I would strongly advise you to view before you buy, I didn't and the finish at the end of the pipe outlet that you see under the bumper is very poor. looks like they have been cut off with a blunt hacksaw.
          A local guiy is making me a set up that are 2 1/2 inch right to the joint, didnt expect it to affect sound a huge anmount but in my opinion will look better although not original.
          James
            The 'bible' (James Taylor's The Restorers Guide ) states "the Mk11 Stags had smaller-bore tailpipe outlets, which are in fact entirely cosmetic....." - however it doesn't give details of what sizes the two different ones are.
              mr greystag if you want a small bore set of rear pipes ? my mate lives about three mile down the road from you and has informed me he has a nice pair that you are welcome to foc . very nice man indeed . if you want them send me your mobile by pm and I will pass it on he can contact you and you can make arrangements to collect them .
              regards
              steve
