STAG CHOKE
    STAG CHOKE
    Hi Guys!
    Am sure someone could tell me! ?
    After removing my Choke cable on my 74MK2 STAG revealed why I never had any panel warning illumination when on!- you guessed it....no switch! obviously had been some problem in the past.
    Anyway I bagged another one of EBAY which has arrived- but sadly no switch! -am trying to source.....I have found a purple wire hanging loose off the loom-nearby which I assume is for same-??
    What I cannot get my head round is how this is fitted relevant to the choke pull ? is there some sort of bracket assy which is not shown in catalog?- have had a nosey at RIMMERS piccy- just shows pic of switch but bothin to relate how it is attached- havin said that if I had one in my mit- could probably suss out!!!??
    Gratefull for any advice!
    :dude:CHEERS!
    PHIL
    Phil,
    Purple wire usually means battery-live.This is probably the original radio supply, or possibly for the cigar lighter. I am fairly certain it is not for the choke. I cannot get to my ROM until the weekend, but perhaps someone else can help by looking at a wiring diagram for you.
      CHEERS DAVE! YOU PROB RIGHT! HAS HAD A NEW PULL OUT RAD FITTED!!!
      WILL HAVE ANOTHER NOSEY!!!
      CHEERS!
      PHIL:dude:
        Hi Phil, theswitch clips around the choke outer cable housing just after the threaded part and before the flexible part. A small plunger from the switch is located into a hole in the housing.
        Gez.
          Hi Phil
          My ROM is saying White /blue for the choke switch cable.
          Carbs suck.
            I hope the pic above helps...
            As Stagdad says...White /blue for the choke switch cable.
            Gez
              Hi STAGNUT!
              CANNOT THANK YOU ENOUGH ME OL MATE! DONE ME PROUD! REALLY BEEN CONFUSED ABOUT THIS!!
              THANKS SO MUCH FOR DIAGRAM! AND WIRING INFO!!!! CAN SEE THE LIGHT NOW! HOPE CAN HELP YOU OUT SOMEDAY!!!
              :dude:CHEERS!
              PHIL
                CHEERS JEZ!
                REALLY GREAT TO RECIEVE HELP ON ISSUES!
                ALL THE BEST!
                PHIL:dude:
                  Phil,
                  All you need now is for someone to show you how to turn off the Caps Lock on your PC
                    hi Dave! get your drift........me ol eyesight not what it was!!!!!!!!!!!!!!! phil:dude:
