Taken gearbox nose extension off gearbox to replace oil seal. its the one that the release bearing sleeve slides over. I am now about to refit it but not sure which way round it goes. There is an oil hole in the gearbox casing beside the input shaft bearing at 9 oclock when looking from the clutch side, and the gasket has a cut out that aligns with this. The gearbox nose extension has a recess (oil hole) which I thought should align with this (at 9 0'clock ) hole in the gearbox casing, the workshop manual says this should go at the bottom. Am I not understanding the operation ? does this oil hole go to the bottom or the side?
Gearbox nose extension
This topic is closed.
