Wheels
    Wheels
    I have a '74 stag auto, at the moment it has 14" spoke wheels
    I also have a TR6 with 15" spoke wheels,
    will the 15" from my TR6 fit on my stag and not cause any problems?
    any help would be greatly appreciated
    I think I'm correct in saying the 6 has a different offset, may be proved wrong though
      I know that TR6 wires will fit the Stag, they do have a different offset but there are people on here that have done it.
      provided the offset is no more than +6 you’ll be ok as I have 16” x 7” Miniltes which have a +6 offset. Minor alteration was needed to the arch overlap, the part where the inner joins the outer arch. On the basis TR6 wheels are not as wide as 7” you should be fine but if you get the offset of the wheels you have you can input it against the current wheels and offset on this site and it will show you how it will look:
      Use our tire size tools to calculate specs, speed, gear ratios and more. Browse tires by size, vehicle, or brand and compare prices online all in one place.
